Would you spend 1K for a selectable front diff locker to replace your Visco Lok unit?
  • Yes
    Votes: 40 70%
  • No
    Votes: 17 30%
Status
Not open for further replies.
21 - 40 of 49 Posts
I believe that the Rhino is a 3.67 ratio, which is close enough to our 3.6. Or at least I know the Maverick has a 3.6, can anybody with the Commander verify that it's the same on them? And I'd trust something from Yamaha more than I would anything from Arctic cat. Get the entire Rhino differential bolted into the front of your vehicle, get one of the aftermarket axle suppliers to make axles that have rhino inner cv and a Can Am outer cv with your axle length, and all that's left to do is get it wired up and get the driveshaft hooked up to it. You could probably even cut the cv off of the rhino, and weld it to the Can Am cv.
yes i agree 100 percent, but! do you really think the diff for a 30 h.p. rhino could hold a 100h.p maverick???????
also what about the new gator ? doesnt it have a locker? if so how close is it to the correct ratio? and wouldnt that be a better option? considering it has much more power than a rhino??
John Deere part number would probably be way to expensive....lol
Save
Discussion starter · #25 ·
Very interesting.
GKN Visco Lok: GKN Driveline : Automotive Driveline Components : Visco Lok LSD
GKN Electronic locker: GKN Driveline : Automotive Driveline Components : Electronic Locking Differential
Says the electronic locker "Can be combined with any limited-slip differential"
Hmmmmmm....
Here are the Visco Lok specifics. Looks like the technology is tunable on a per application basis: "The progressive locking characteristic is tuned by specific silicone fluid viscosity and clutch pack sizing"
http://www.gkndriveline.com/drivelin...coLok-engl.pdf
Based on how the electronic locker is purported to be available for combining with *any* LSD, it would appear on the surface that Can Am only need ask GKN (after being encouraged to do so by a critical mass of us)...
All those interested should continue to answer the poll and then we can plan on using an appropriate channel to contact Can Am and point them at the numbers of current, and possible future, owners that want a selectable locker.
The obvious answer is the same company that makes the current Visco Lok unit. And they already also offer an electronically selectable locker that "can be combined with any LSD". It appears that technical hurdles are not the issue...
The problem with adding anything to the visco is that the driver side runs off of the visco, if you weld the spiders the drivers side will still turn indepently. I welded my spiders and had to go back and drill and pin and weld the visco side to get full lock up. If you switch front diffs you will also need custom axles. Yes rikmil did get the ball rolling with eaton and highlifter. HL may not like can am, but they are in the business of making money, they treated me very nice, and we're extremely helpful in the whole process
Just thinking out loud here, but if one was to replace the fluid in the visco loc with say a metal suspended fluid like in some automotive shocks & had a electro magnet inside the system then when you turn on the magnet (on/off not variable) the fluid could get thick enuff with sufficient metal suspended & large enuff magnet to turn the visco into 1 solid locked up unit until the switch/magnet was turned off
how does your rig turn now with the locked up front end?
GKN looks to be the most promising, i emailed them to see if in fact they are the OEM manufacturer of the can am visco lok. I cant imagine they are not, the trademark on the visco lok looks to mean one maker of the trademarked unit. My theory anyway, if it holds i would be surprised if that electric locker would not bolt right in to the commander! That would be awesome for sure!
guys i spoke with rob today from gnk and he is on our side but because of brp and confidentiality laws he cant speak for them can only do what they say! but he does agree that the can am should have a locker option. and he said he would personally contact them to see if they would like to re-evaluate, the locking diff. he told me a few years back, that brp did in fact inquire about a locker but never pulled the trigger ! so he told me he would personally speak with brp today and run it by them again. they are indeed the makers of the visco and they do have the technology! unfortunatley again due to confidentiality he couldnt call me back and say yes theyr interested or they didnt wana hear it. but at least he is trying and he give us a link on the maverick forum, to complain to brp and ask for a locker please ever1 blow this thing up!!!!!!!!! please. im not computer savy enough to post the link but look on page 5 of maverick forum and you will see it! come on guys we are barking up the right tree this time!!!!!
We need to hound brp about this, the company already has a locker we just need can am to option it for us. Email brp and tell them u want a LOCKER
Save
So does GKN have a diff with a locker than I can drop in my commander? Or can they make one? Will they make one for the after market. Or do we got to wait to see if they make a production one in the future for BRP. Sorry if I missed it somewhere.
yea u missed it a little but i wasnt super clear either! but yes where i said that he cant say but he will do what brp want? thats what i meant they only make parts for manufacturers and do not and will not mess with the aftermarket! but he made no mistake about tellin me that if brp wants to do it then it will happen all they have to say is the magic word! they do not have 1 ready to drop in this second, but what i gathered from our conversation. that when brp inquired about this before they made a computer model that was gona word but never made in real world form! so i am under the impression that if brp says its a go it wouldnt be long because it has already been designed , just has to be made!!!!!!!!!!
So why has 15 members voted no! Are you serious?! Who wouldn't want a selectable locker! It's the best of both worlds!
Save
This is the answer I got back,
Jeff,
Unfortunately we do not, but we could (we do the Rubicon and F150 lockers for example). Unfortunately GKN does not operate in the aftermarket arena and we would only work on a Visco-Lok alternative at BRP’s request. You really need to address your question to BRP themselves. They have their http://www.canamoffroad.com/community/my-canam-idea link that is a suggestion box. I’m sure that if enough Can Am owners asked for the same thing then BRP would take notice.
Kind regards,
Rob.
BRP wont do it for safety/steering issues even as a accessory is my guess. Thanks law suits....
Save
Hey Rowdy - I think the key to the question (for a few owners at least) is "Would you spend 1K...?" for this upgrade. :unsure:
Save
21 - 40 of 49 Posts
Status
You have insufficient privileges to reply here.
