Switch issues
20K views 30 replies 11 participants last post by  acefire
#1 ·
Does anyone have issues with the canam rocker switches failing? My hi/lo beam switch no longer has the 'detent' click and is permanently stuck on low beam. My winch switch is Now also acting up it always lets the winch out but takes some messin with it to get the winch back in.
I believe it will be going to the stealer for repair as I still have warranty and it also has a strong coolant smell which has developed over the last week. Nothing showing up underneath just smells like coolant when running. Machine is 2016 1000xt it's been used but has a fairly easy life of logging and dirt road cruising with some snow plowing now.
#2 ·
My winch switch didn't even make it 6 months. Knock on wood that is the only one that has given me trouble so far.
#3 ·
The full power draw of hi-beam goes into the switch . Low beam passes onto a relay .
The China switch just can't handle the amp draw .
A winch contactor that has taken on moisture will draw to heavy of a load for the stock switch . If you have a good BRP switch and give it lots of electrical grease on the inside to stop the internal spark that burns the contact points it will last very good for a China switch
#4 ·
Thanks for the tip Troy!! Next time I have a issue or even have the dash apart I'll have to do that.
#7 ·
How many of there tech's could even service a switch . Lol
#13 ·
#14 ·
If you can't feel the detent it has melted and it's toast .
If a switch still has the click feel but don't work you can sand the points and grease it and it will work again .
#15 ·
#18 ·
Lucky you with the tool, I had to McGuiver mine apart lol
#19 ·
your having switchues?
#21 ·
I've owned my 2013 limited since October of last year. Purchased with very little mileage (900kms) so not like it was well used. Since that time I've had to replace both my hi/low beam rocker switch and winch switch. I could understand the winch switch being it does get used quite frequently in the winter to operate my plow but hi/low light switch almost never gets used. I also have the BRP light bar on the roof, the backlight in one of those switches has also failed. I have not been overly impressed with the BRP switches.
#22 ·
Not many switches on the market in that style any better. Mine now have 4200 miles on all the switches. But I don't wash the dash. So I don't know if that's why mine still work or not. But they all get used frequently except the whinch switch. Winch is 4 yrs old still in the box. Lol
#23 ·
Hmm and I'm on my 3rd front winch on my mav with a 4th ready to bolt on .
Planetary's break or the winch drum busts I've been having bad luck
#26 ·
Issue with winch switch resolved .. I took
It apart and 'cleaned' it. It was not necessarily dirty there was some minor signs of wear and pointsof contact for up and down. A coat of dielectric and back together it went. Has worked great since thursday
#28 ·
..... but has a fairly easy life of logging.....
I have some buddies up here that would take issue with that! I tell them they're just a bunch of pussy's out knocking over sticks and drinking beer every afternoon at 2:00:icon_ poke:
I tell my buddies that all the time especially the one who got a brand new skidder this year. I believe you failed to miss the part that said logging and dirt road cruising
#29 ·
I didn't miss it, just having some fun witcha. How to get a logger to cry? Borrow his new equipment and bring it with a scratch. Give 'em a season and it'll look like he rolled it 5 times after the road gave away.
