If your unit is shut off , does it shift easy . If it does the good ol factory might not of put any lube in the oneway bearings . Dry bearings don't spin easy , that causes drag and that makes hard shifting as the secondary is trying to turn . For easy shifting the secondary should NOT be putting pressure on the gearbox . Just my .02 cents
