Front overhead LED light bar wiring?
19K views 11 replies 6 participants last post by  Donie1
#1 ·
New HD10 owner. I put two rear LED work/back up lights on the rear of the roof last night. Lighted switch off of Amazon and wiring harness with relay. Took power from the accessory post under the dash for the switch and to activate relay, relay direct from the battery. Ran the wiring in a loom down the tunnel from the dash to the battery area and up the post behind/next to the passenger seat.
Next is the 21 inch LED light bar for the front. I want to mount it on the roof so the snow plow doesn't interfere and for a greater dispersion of light. Was hoping to fish the wiring up the A pillar on the passenger side, but it does not appear to be open at the bottom. Anyone have a recommendation on getting power to the roof from the front dash area? Don't like the idea of running power all the way up the back to the roof, then to the front.
Thanks, appreciate the great forum!
Dan
#11 ·
True, but figure in time and gas to get stuff plus your labor to make it all up plus a lot of guys are not handy enough to do it correctly so why take the chance of burning your 15k-25k machine up to save a couple of bucks? IMO.
#9 ·
Read the earlier reply, Can-am makes the perfect wiring harness that includes a wiring post for $40.00, hard to go wrong for this. It hooks up the the three post hookup under the dash.
#6 ·
Seems the wire to the roof came with the roof guards we got, or maybe it was the roof? I believe we ended up with an extra one for some reason. Since our machines are setup for our work, we of course end up making all sorts of parts from them. Nonetheless, if we can purchase something already made for them, we do. My time does have value. Although that's not what my spouse says :)
#4 ·
Like Arly said BRP makes a nice cable to go to the roof, I also have one in my Defender
the BRP wiring harness is Part# 715003094 price is $39.99. The front roof liner is a nice addition, Hides the wire harness and has opening for the switches, also has a place if someday you decide to install a stereo and speakers.
I installed the roof mounted LED bar for the same reason as you are going to
