1 - 6 of 6 Posts
Ok, stupid question time. I've searched multiple times with different key words and no luck. What is the connector black and red use for in this picture, I assume the other one is for buds but shouldn't it be plugged?
Like Mud Yapster said, check it for power with and with key off. I found out the hard way that the frame on these is not a good ground.
I installed EZSteer last month and the directions had me remove the white cap and plug the "switched 12v" line into this source. The connector on EZSteer fit this connector perfectly. I'm guessing the black line is ground.
1 - 6 of 6 Posts
