· Registered
The display will show H, will not show L. will not go over 20 mph. This SBS is new to me, it's a 2016 commander 800R. Looks to be ridden hard. The engine runs well. I did replace the primary clutch, secondary clutch, and belt. This was a nightmare. Thank you, Dremel! Nothing really changed in how fast this machine will go. Any advice would be greatly appreciated.
Wood Cone Office supplies Gas Art
· Administrator
I assume the seat belt switch is working properly. When you turn the machine on is it scrolling performance key across the dash? If not you may have a key programmed as the safety key.
· Registered
Yes it show "Performance Key" on display. First test run after both clutches and belt replacement got up to 40 mph in H and smoked the new can am belt. L tops out at 20 mph. Explain the seat belt switch. I just kept the seat belt latched behind me. when test driving.
· Administrator
If it got up to 40 seat belt switch is working . But if you got to 40 and smoked the belt something isn’t right either in the primary or secondary. When it hits 20 in low what are the rpm’s showing?
· Registered
Does sound it's not the problem you are having, but if the seat belt is not connected it will display a seat belt message on the display and speed will be limited to around 10mph I believe.
