1 - 9 of 9 Posts
· Administrator
thanks
I was more concerned w/clearance; I had thought they were both that same mount patten
They should fit but with factory x3 wheels the center cap snaps into the hub. So you wouldn’t be able to run with center caps . Unless you got a good eye and drilled the holes in the hub for the caps to clip in.
1 - 9 of 9 Posts
