1 - 6 of 6 Posts
I was reving my canams when out of nowhere i i heard it popping then it sounded like it wanted to cut off and it did then i tried to turn it back on and it started but cut off instantly and when it turns on it sounds like a tractor and cuts off i don't know what's going on if someone can help me please do
Tire Wheel Car Motor vehicle Hood
helps to know year and miles.... first plugs, then valve clearances as a foundation. Of course confirm fuel delivery.
Pull the codes
1. turn key to lights on position
2. use mode button and scroll to engine hour (EH) on gauge
3. press and HOLD the mode button while quickly toggling between high and low beam ( min 3 toggles in 2 seconds)
4. If there is any P-CODES they will be displayed
Pull the codes
Good info. I'll have to remember this
1 - 6 of 6 Posts
