2016 Maverick XRS DPS
~10000 miles on it
Upgraded the primary clutch to use the keyed turbo sheeve
New motor at 9000 miles
New belt at motor change
Swapped to 30” tires a couple hundred miles ago
Was out riding last weekend and apparently the bolt that holds the secondary clutch on backed out and allowed the secondary clutch to come off the shaft:
I had this apart several hundred miles ago when I swapped in my new motor. I am confident that the surfaces of the shaft and the ID surface of the clutch that interfaces with the shaft were very clean and defect free. I am also confident that I torqued the socket head cap screw per the instructions. I think I replaced this with the aftermarket bolt as a preventative measure for this very thing….. but I am not 100% sure at the moment. I am also not sure if I loctited the bolt threads. I am sure if the instructions said to Loctite it I did, I just don’t remember if the instructions said to.
I am in the process of ordering a roller secondary clutch and new weights/springs for the primary to help with the 30” tires. I know that my stock secondary is pretty well worn so that helps justify the change also. I want to make sure that this doesn’t happen again. Any idea on what I can do to help keep this from happening again?
Dan
~10000 miles on it
Dan
