1 - 8 of 8 Posts
I washed engine on my 2018 Can Am Defender and then when accelerating in High there was hesitation accompanied by a high pitched whine until maybe going 5-10 mph then disappears. Oddly it does not do this in Low or Reverse. Any help would be appreciated.
That’s quite possible, I am not an expert on that stuff. However that has been suggested. If it is the case how does a little water on the belt cause the hesitation and how does one fix this issue? I really appreciate the help!!
Water is a lubricant. There should be a drain plug, hose, or something in the bottom of the cvt housing. Refer to your owner's manual. A residual amount on belt or sheaves will evaporate/dissipate with operation.
There is a drain, opened it and it was dry so maybe there is a small amount only. I will run the sucker for a bit tomorrow and see if it dissipates:)
Thanks for the advice.
Updates ?
Sorry no update. Waiting on some clutch removal gizmo to remove and clean/dry belt. However it’s been almost a week, I drive it about 1 mile yesterday and it still makes noise. Seems like it wud have evaporated? I did check the drain bottom of CVT and no water in there. I’m thinking maybe something more serious.
1 - 8 of 8 Posts
