1 - 17 of 17 Posts
Hey guys, is there any where other than youtube for drive shaft removals? Seems to be few are far between on YouTube.
No.
Rear. Pull 4 bolts from frame thst holds it on.slide diff back. Use 13 mm wrench n get bolt out of center joint U will have to move gas tank or cut hole in metal plate under. Unbolt from rear of trans slide it off
Front. Take out 4 bolts holds diff in. Unbolt center 13mm bolts from shaft on diff side and motor side Slide diff forward pull off
I did not have to cut a hole or move gas tank for rear shaft. Removed it twice already. Just unbolted differential, removed both bolts that hold the yoke to the diff and engine off. Back differential and took the drive shaft out. I did have the box off and the axles and a arms so I could work easier in there.
I have taken my rear shaft off way to many times and sliding the diff back and a short wrench with a offset is all I used for the nasty bolt that hold the shaft to the gearbox
Discussion Starter · #6 ·
Could i just remove the u joints to take off the drive shafts? Im just trying to get at the gear box to replace a stud i snapped off
If your UJOINTS are still good I wouldn't do it that way. Safe yourself a lot of hassle and just removed the bolts needed to work at it.
No.
U-joint center bolt is 1/2" on mine. Almost realized too late and was close to rounding it off.
I'm stuck trying to get the yoke bolt out of the gearbox. Looks like I'll be pulling the gas tank to get to it better.
I was wondering, does it help to apply heat to the bolt to break down the loctite holding it in? Has anyone here tried it and recommend it?
The bolt on the diff yoke was pretty stubborn. I ended up removing the u-joint and then the bolt using an impact wrench. I'd like to leave the other u-joint intact though.
I have warmed up the yoke bolt and it helps to soften the lock tite
I ended up putting some heat on the yoke bolt last night but no luck removing it without removing the gas tank first. Once the tank is out of the way, there's whole lot more room to get at it and put some torque to the wrench and get it to turn. It's much easier with the tank out of the way.
Any tips on pulling rear yoke from the gearbox? Bolt came out easily, heated up yoke and its on there like it’s welded on. Soaked it overnight with penetrating oil and still no dice.
Got it! My rear winch couldn’t pull it off without beating it with a hammer.
easier to keep the wheels on, hold the wrench on the nut and turn the wheels, plenty of torgue to lossen them. no need for tank removal or axles for that matter, re ove rear diff bolts and the prop shaft compresses so there is plenty of room.
No.
1 - 17 of 17 Posts
