81 - 97 of 97 Posts
Vendor
Discussion Starter · #81 ·
Wanting to control when the fan of your Can Am Commander 800 or 1000 is ON? The UTV INC easy to install plug & play fan over ride kit is one to go with! Amber LED Carling switch & OE connectors for a simple plug and play install. The switch will illuminate amber (orange) on the top when the switch is activated. In line 30 AMP fuse & holder makes this kit work for both the 2 and the 4 seat models of the Can Am Commander without issue. Instructions are included with this kit.
LINK: https://www.utvinc.com/utv-inc-can-...ber-back-lit-led-plug-play-fan-over-ride-kit/
The kit works good and anyone can install it .
I bought one and gives it two up
2013 1000X: RT Pro 2" lift, Warranty Killer low ratio gearbox, fan override, clutch lock up mod
Is there an option for turning the fan off
I was asking if the fan could be turned off, not set to factory. It would be an on/on/off.
Vendor
Discussion Starter · #88 ·
The fan over ride kit is just a simple over ride. When switched on the fan runs continuosly until the switch is turned off. It does not have a multi function switch, just ON/OFF. It will not allow you to switch the fan off when it hits the factory default temp and comes on. It is designed to allow you to run the fan before the vehicle heat's up when driving slowly with little air flow.
Vendor
Discussion Starter · #90 ·
81 - 97 of 97 Posts
