1 - 20 of 28 Posts
Vendor
UTV INC POLARIS & CAN AM SEAT BELT BYPASS OVER RIDE WIRING HARNESS
Installing aftermarket racing harnesses into your 2014+ Polaris RZR, General & Can Am Commander or Maverick and need to bypass the OEM safety feature of the seat belt clicked in? UTV INC has a simple plug in bypass over ride kit for this! Designed for racing purposes, not so you can drive around without a seat belt on. UTV INC ALWAYS RECOMMENDS DRIVING & USING YOUR UTV WITH A SEAT BELT (HARNESS, RESTRAINT SYSTEM, ETC.) ATTACHED TO YOU AT ALL TIMES! This product will override the factory speed limited in the ECU when the stock seat belts are removed or "unclicked" from the machine. This was designed for the racers who run an aftermarket restraint system in their machines, however it will work on any 2015+ Polaris RZR machine for any types of riding. AGAIN, YOU MUST WEAR YOUR SEAT BELT AT ALL TIMES WHEN IN THE VEHICLE - AS A DRIVER OR PASSENGER! UTV INC will not be held responsible for any damages or injuries while using this product. Use at your own risk.
Will fit:
2014 & newer Polaris RZR XP 1000
2014 & newer Polaris RZR XP 4 1000
2015 & newer Polaris RZR 900 Trail
2015 & newer Polaris RZR 900 XC
2015 & newer Polaris RZR 900 S
2015 & newer Polaris RZR 900 4
2015 & newer Polaris RZR XP Turbo
2015 & newer Polaris RZR XP 4 Turbo
2016 & newer Polaris RZR 1000 S
2016 & newer Polaris Sportsman Ace 900
2016 & newer Polaris General 1000
2011 & newer Can Am Commander (all models)
2013 & newer Can Am Maverick (all models excluding X3)
2015 & newer Can Am Defender
$11.00
LINK:
https://www.utvinc.com/utv-inc-polaris-can-am-seat-belt-bypass-over-ride-wiring-harness/
Vendor
Want to do a clean harness install on your Commander? Check out our UTV Inc. seat belt bypass over ride harness.
Vendor
Discussion Starter · #13 ·
Upgrading your Commander with harnesses? Check out the UTV Inc. seat belt sensor bypass harness.
Pull driver side , side panel off and follow from seat belt latch about six inches. Unplug seat beat harness and plug bypass in and zip tie it off.
1 - 20 of 28 Posts
