1 - 2 of 2 Posts
I have the opportunity to pick up some tyrex rims and tires. I'm about 90%sure the pattern will match but the stud holes are 12mm and we have 10mm. Is self centering lugs the answer or is there better solution? Thanks for any insight!
Bolt pattern is 1mm difference. The hole isn’t a issue just got to use the right lug it . If the wheels use the flat washer face nut I would pass. Those wheels actually center with the studs. If they’re the wedge nut line on the commander they will work .
1 - 2 of 2 Posts
