1 - 7 of 7 Posts
I have lost a good but of my turning radius to the left since swapping my tierods last fall i can only get about 3/4 to 1 full turn to the left plenty of turn on the right could i have got something out of alignment?
Need to count the turns on the steering wheel from left to right then turn steering wheel to center. Then align the front again .
I was thinking turning radius, as in trying to make a u-turn or a full circle. I have a pretty dang good u-turn/circle radius when I mash the go juice...
Discussion Starter · #6 ·
So i only had about 3 turns from one side to the other i i centered it up and it help a bit but still cant go as far left as i can right ah this unit is gonna be off to better days soon lol
Sounds like it still isn't center for whatever reason. Shouldn't be nowhere near 3 turns if you got three something else Is going on. Factory is 2.5 give or take a smidge. The quick ratio rack is 1.5. If its centered it should turn equally both directions unless something is bad.
1 - 7 of 7 Posts
