i have a 2012 commander 800. 9 mos of the year it leads a lazy life but in the winter i work it pretty hard plowing. i know the can am's flash the engine light time to time and goes away, but the other day i plowed for over 10 hours and i got a transmission message pop up. Never had that before but popped up a few times. It didn't pop up in the last couple of days of lighter plowing.
Besides fluid level, what sort of maintenance should i be doing? My tools can get me farther than my skill which could be dangerous but just don't want to slowly kill my baby and winter has only just begun.
Trans message is a signal failure from the angle rotation Sensor on the gearbox. It tell the exm what gear you are in .
i was hoping you'd chime in Ace! So if the warning hasn't shown up for 2 days after, am i good or do i have some work to do?
Maybe you are lucky maybe not. If it has gone away I would al the least unplug it and grease the plug. But if it starts coming on again you will probably be working on it . When they go bad it doesn't take long before it goes out and puts you in limp mode. Buy if it's getting lost when you are in low. You can oder sport low mode from dz powersports that will fool the ecm into thinking its in high all the time.
