1 - 3 of 3 Posts
New to UTV’s. Should I use tire sealant in my 2012 Commander X to prevent leaks or flats from small holes that may occur or go without?
Depends on what you are doing with your machine. I ride on sharp rocks most of the time and have used Slime for quite a few years. I find my tires bleed spots of green from all over after being parked for a while, don’t need to add any air. So I suppose they are doing their job for me.
Slime will work fine though messy to use. Also, most tire repair shops hate Slime so it is better to inform them prior to fixing or replacing your tires. I just bought some atv accessories including a tire plug kit. I will bring this kit with me when I go out and explore the trails.
1 - 3 of 3 Posts
