1 - 6 of 6 Posts
Hey guys.
I have a 2019 800R with the stock 12” wheels and Bighorn tires. For now, I use it 100% as a pit vehicle to tow my race car at the drag strip. I want to get new wheels and tires but I need to keep the track width of the front only the same or slightly narrower than it is right now. The spot that I park it in my trailer is very tight (front only). What I would like is a 14” or 15” wheel with the proper offset for the front, and a front tire with a max width of 9” or less. The rear can be wider as long as the tires are the same height as the front. I have looked high and low and can’t seem to find what I am looking for. The tires seem to be the hard part to find. An all terrain or even a DOT type of mud terrain would be great. Any ideas?
Tires are the easy part. The issue will be finding a wheel 7 inch wide with a 5/1 offset. Typically aftermarket wheels are 5/2. With will putt you about 2 ish wider in the front. 5/2 would keep you the same in the rear with a 9 or 10 wide tire.
1 - 6 of 6 Posts
