1 - 4 of 4 Posts
I am a new commander owner. I have a 2020 commander 800 and I am trying to wire up a stereo system which I have never done before. Any help would be greatly appreciated.
I have 2 kicker 6.5 tower speakers, a gravity audio 2 channel marine amp, a mictuning rocker switch, and an audio pipe marine Bluetooth controller. The amp comes with a wiring diagram so I can figure out how to hook speakers to the amp buy I have no clue how to wire the positive and negative to the battery with the rocker switch or the Bluetooth controller. Please help. I have attached photos of the parts listed.
RCA jacks Red to red white to white . Red wire to power, black to ground, blue to accessory power.
Power in the middle from battery . bottom is power to what you want power to. Top is the ground which turns the switch light on when switch is in the on position. And if that don’t work flip the bottom hot with top ground .
1 - 4 of 4 Posts
