1 - 8 of 8 Posts
Do you know if the steering linkages can fit on a 2013 Can-Am Commander 1000 XT? If so I would like to have them. Thanks
Hello Paul
I looked up the part numbers on the can am web page. The steering column is the same but the steering racks are different. Don't know if the tie rods I have will fit onto a 2013 rack.
Hope this helps.
That steering shaft is for a non dps model.
11/13 tie rods are the same inner but true outer ends are different. 11/12 10mm bolts 13 up 12mm bolts .
I will take the steering shaft . Mine is dps but I have another use for that shaft .
1 - 8 of 8 Posts
