1 - 13 of 13 Posts
Been noticing an oil leak so i took the panels off and this Only place on the stator cover that i can find a leak. Should i loosen bolts enough and put some silicone rtv and retighten. Or take stator cover off and put a new gasket ?
There is a O-ring under that crank sensor that gets hard from heat . Remove it and go to your auto parts store and buy a new o-ring for .75 cents and your set
Hard to tell from the pic but i took a flashlight and looked around the sensor and it is dry around it. I took carb cleaner and sprayed and cleaned where the stator gasket is and there is a small leak to the left of the bolt where the cover meets the case
Edit it is right at the little raised spot in the mold on the case
Where the wires come out of the cover is a spot that seeps oil on many
Yeah I remember reading one of your older posts where you mentioned that and i looked there first and no leak. Should i remove the whole cover and reseal or maybe loosen it enough to get some rtv sealant in theleak spot and retorque ?
If you crack the cover loose you better install a new gasket .
My outlander started leaking out of the stator wire bundle so I took compressed air and brake cleaner to where the wires come out . I got them clean and dry , then I used black gasket maker silicone and worked some into the wire group next to the engine . It has been leak free since I did it .
Reactions: Bill_Rowe
Good information. Will you be traveling through Henderson CO anytime soon to show me this process in person. Thanks, Booger.
I don’t think so as I am having a bit of some health setbacks . Fall ride is in question ?
Discussion Starter #10
Got a little silicone in it and no more leaks :)
My 2012 1000 XT is leaking at the exact same spot, verified it today while chasing a bad oil leak that has been driving me nuts and making a mess of everything underneath...
Discussion Starter #13
Did this work?? Did u end up just cracking it loose and getting a bit of silicone in there??my commander is doing the exact same thing at the exact same spot
Yes worked for me Loosened it a bit and worked some silicone in there and let it sit to skin over and then tightened back up
1 - 13 of 13 Posts
