1 - 2 of 2 Posts
I have a 2015 Commander 800. Just last week the starting of the motor was really weak. As if the battery was dying. I had a new battery charged up to 100% replaced it and still the same slow cranking. Finally, 3 days ago it would not crank at all. I checked the battery with the voltage and it was 12.5 volts. So I ordered a new starter and began to tear into the engine cover. I found out that you just can not take the starter out without taking the clutch housing off. So in order to take the clutch out, I need the clutch remover tool and the second clutch expander. So I have to order those. Is there anything else I need to order? Thank you if you could help me out.
1 - 2 of 2 Posts
