Having this same issue right now. Was it ever solved?
I'm having the same issue did you figure out what it was?Having this same issue right now. Was it ever solved?
What year Commander? Did you jump straight from battery to starter? If using start relay, did you you jump the main terminals or jump power to the relay coil? If using coil, did you also jumper the ground side of coil? With fuel pump, did you run a positive jumper only or a positive and a ground?I’m having the same issue. Any leads or thoughts that would help. Everything comes on and key registers but no fuel pump prime and no crank. Can get both pump and starter to work manually.
2014 commander 800xt . Jumped the solenoid for the starter. Both big posts And Put ground to the fuel pump just to make sure they were both working. When you turn the key on the dash and everything comes on it acknowledges the performance key but will not start or prime.What year Commander? Did you jump straight from battery to starter? If using start relay, did you you jump the main terminals or jump power to the relay coil? If using coil, did you also jumper the ground side of coil? With fuel pump, did you run a positive jumper only or a positive and a ground?
ok, checked and cleaned the grounds, cleand them on battrty, 3 on the side of the battery box were dirty but not badi have not, im changing the belt this weekend, my neighbor was having a similar issue on a polaris 1000 but getting an engine light, change his belt and it seemed to fix.
i will change the belt and check and clean all grounds this weekend. i will be in touch. it may get into next week, weather permitting.
thank you.. talk soon!!
