1 - 16 of 16 Posts
Vendor
Check out our new Smart Strap helmet and goggle strapping set up.
Only $19.95
They make using goggles with a helmet super easy and convenient. If you are using a helmet and goggles without a set of these you are missing out for sure.
You can pull them on and off with one hand and leave your goggles hanging while not in use. No worry's about where to put them when you take them off for the short stops to cool off.
They will work with all Wolfsnout™ googles as well as other high end goggles such as, Oakley, Smith, Scott, Spy, Fox. 100% and Dragon.
Click here Groundforce_antisand_antidust_goggles
WILL NOT WORK WITH / Smith Warp, Scott "Works Series", Scott Xi No Sweat, Fox Main Pro, Scott Pee Wee, Smith Intake, Smith Piston
Graphic, Smith Sonic, Smith Fuel, Spy Magneto, and Thor Hero goggles.
At Wolfsnout We make products that make your riding a little better.
Is this setup different from the quick straps that have been around for 15 years or so .
Vendor
Yes they have been around since the mid 80's. Our design is easier to remove and replace on the mounting side and our connection to the goggles are a huge improvement.
I have used quick straps and the fast strap from Scott over the years as well. They are great products. We improved an old design. Overall they work about the same as all of the others only better.
1 - 16 of 16 Posts
