1 - 4 of 4 Posts
Hey everyone....I have a 2014 800r...How often are you guys doing matience and how often are you greasing it and what are you greasing?
How often are you changing the oil?
Rear/front diffs?
Gear box?
My 2014 has 1500 kms on it. It had it first service done at 545 kms. SO I roughly got 1000 kms on these fluids.
What are you guys running in be-tween?
Commander fluid capacities
Front diff 75/90
17oz
Rear diff 75/140
12oz
Gear box 75/140
15oz
All API GL-5 Synthetic
Motor Oil 5w-40 Synthetic
2.3qt
I change my fluids once a season just to be safe. That is usually around 100 hours. The front diff and gear box are recommended for 200 hours in the manual. There are grease fittings on the u-joints on the drive shaft and 3 fittings on each set of front a-arms.
x2 on fluids, but i grease mine up especially after a good ride in water and mud. grease is cheap and parts are not!! lol
i grease all fittings on suspension & u joints after every weekend of riding. change oil every 6 months on engine , shock pivots, rear diff & trans. front diff once a year as it' not worked as hard .
1 - 4 of 4 Posts
