2011 can am Commander 1000 run's hot radiators full no mud clogged up in the radiator don't know what else to do runs hot after sitting there for 6 minutes steams out overflow container
If radiator is clean all the way through . Then would have to be water pump thermostat or just full of air.
If fan is coming on when you start it the sensor is bad or the relay is stuck. Thermostat is right behind the radiator it’s a barrel shaped Tee. It’s a plastic sealed housing you have to replace the whole thing. No way to actually get to the thermostat itself.
