1 - 8 of 8 Posts
Hey guys, can anyone better than I find the install pics of the rear upper shock mount that shows how to mark the plastics for cutting rather than removing.
Installing on a friends machine and I don't want to remove the plastics (lazy).
Thanks if you can
You could drill a hole through from mount side where the mount will be then go inside and measure out the cut .
Similar to Ed, I removed a couple push pins and then went to the non padded BFH and a piece of flat stock and persuaded it right into place!
Same with me.
1 - 8 of 8 Posts
