1 - 8 of 8 Posts
I'm getting ready to do first oil change for my XT800. I'm going to use Rotella T6 5W-40, but I'm noticing there's a couple choices... "Extreme Temp" and "For Diesel Engines" Does it matter which is used? Thanks
I thought all rotella t6 5w40 was the same. Be careful as they also have a 15w40.
Look at the ratings.
You need API SM and JASO MA-2. This are the specs that BRP has for their oil, so as long as you're using that then you're fine.
-Kris
It shows having all those specs, thanks. I've noticed a puddle of what seams to be dirty oil underneath the drain plug. I replaced the plug o ring and the filter cover o ring. Could this be coming from the filter cylinder when filter was removed?
Did you replace the copper washer on the drain plug too?
There's a good chance it's left over oil from a previous change. I'd recommend some Simple Green or Purple Power and wash it all out, just to make sure you don't have a leak somewhere.
Don't get crazy with a power washer though.
-Kris
1 - 8 of 8 Posts
