Replace front drive axle
6.5K views 4 replies 3 participants last post by  Smiles
I remove the shock, tie rod bolt on the hub, axle nut and lower a arm bolts. All very easy, then I hold the hub and a arms up and out of the way with a ratchet strap. The upper a-arm will allow enough angle to pop the axle out from the hub, then just yank the other axle end from the differential.
