1 - 20 of 23 Posts
Who has removed their air ride in their Ltd to go to a regular mounted shock ?
Looking on information on compressor removal, fault code that will come up and
What to do about it. Pulling the fuse etc. Any help would be appreciated.
Ron
air pump
great question,so far mine is just a expensive on board air pump for filling tires, i just caped air cans with #4 caps
im sure it would throw fault codes and be a constant burden. i would assume a reflash at the dealer or mr rpm could im sure
I did remove them. The removal is straight forward. However you will need a dealer with buds to shut the air system down in the computer or you will be getting faults. It was a little tricky for them but the dealer I go to is awesome and figured it out. If I remember right they could not just go into buds and shut it off. I think they had to disconnect the computer from the machine. Turn off the ACS. Then reconnect. It wasn't hard once they did it.
Discussion Starter #10
Thanks sau4u
I completely removed the compressor and the air lines. For the electrical I just unplugged from the compressor. Then placed those ends in a water proof box and tucked it out of the way under the seat, facing the rear. I did not remove the wiring from the machine. Just in case I ever wanted to put the air ride back on. Its a very expensive add on and sitting in my shed. If I ever sold the machine I may put it back on and take my elkas off.
Night and day difference. I put elkas on all my machines. Don't regret it at all
I did it and love them , I did leave the air system in place and blocked of lines now it's just a tire air pump and not that good at that eater
Any one have a pic or diagram of air lines off compressor.. I replaced cylinder and a friend got ahold of my marked air lines and removed them so he could ride my machine while I wasnt home.. pic would be fine
Part 44b air hose ..which hole does it go into on part 270.. also theres 2 other canisters and hoses which hole they go into.. on part 270 theres 6 holes
1 - 20 of 23 Posts
