21 - 34 of 34 Posts
Was almost the same price as the dealer wanted for 2 replacement u joints.
Yeah, but it depends which year you have. I don't remember how much it was, but I got smoked when I bought a rear one, with joints and all. I spent a couple of minutes crying in the corner of the shower.
I just lightly tapped mine on had no issue... different question when you remove the yoke from the diff is it supposed to leak a little
No the seal is the seal. The wear ring just takes up the space between the yoke and the seal. It keeps the seal from wearing out the yoke .
Once you pull the yoke out there’s nothing to hold the oil in . But if you replaced the wear ring you need to replace the seal also . Or you will be right back in there again soon.
Seal is in the diff . It seals on the wear sleeve . Wear sleeve takes up the space between the yoke and the seal . So the seal doesn’t wear the yoke out. Much cheaper to replace the seal and the wear sleeve than the seal and a yoke .
Anytime you replace the wear sleeve you replace the seal. Every time you replace the seal you replace the wear sleeve . By the time the wear sleeve is worn out the seal is as well. You never replace just one . It’s a big job to go back in to do the other several hundred miles down the road.
Thanks for the quick replies haha I changed the wear sleeve just because I bought a new yoke it went on super easy just tapped it lightly with a rubber mallet
21 - 34 of 34 Posts
