1 - 8 of 8 Posts
Before I buy another radio system for the sxs… I currently have a bazooka party bar in it. Once I turn the wheel, or use any kind of auxiliary light (high beams included) the bar cuts in and out? Anyone know what’s causing this? I’d like to make sure it’s not going to happen after spending more money on tunes.
Also you need to put a on off switch on the main power wire going to the bazooka tube. They draw enough power to kill the battery when parked for long periods of time. My buddy has the 24" and it killed his battery in two weeks even though it showed to me turned off on the tube.
Discussion Starter · #6 ·
I always unplug the two prong connection, sits right over my head
Discussion Starter · #7 · (Edited)
Just got to fooling with it trying to weed out options, turned on two light bars, turned steering wheel back and forth, highs lows, waited for fan to cut on. It seems to play fine until the volume on the bar gets cut up… it can’t be distortion because it will play fine using less power?
Appears to have a Duralast ETX20L battery in it… anyone know about these?
1 - 8 of 8 Posts
