1 - 4 of 4 Posts
· Registered
So I just put rt pro 2” lift and springs and put the axle stenders and circlips on the rear axles. When I try to turn the axles by hand it seems like the diff is locked up. I have it in neutral and driveshaft is trying to spin but I can’t get it to move
Are the HD circlips compatible with my Mav diff?
I can’t imagine why it’s locked
· Administrator
Do you have it in the air or on the ground. Is the swaybar bolted in. If it's in the air and swabar isn't attached you may have to much droop and the axles are bound up. As for the stenders I personally wouldn't use them unless the axles were to short after installing the lift. The clips won't effect anything other than the extra force it takes to pull the axles out.
· Registered
I did not have the sway bar bolted in but I tried picking up on both sides and didn’t make a difference. I pulled driver side out and put back in and I could then turn them with some effort. I’m lost as to why it was locked up though
The axle stenders go on the axle before you slide it back through the swing arm right?
1 - 4 of 4 Posts
