1 - 19 of 19 Posts
Popping axle 14 1000 Commander need help can’t keep the axle in On the driver side tried everything new clips and as far as putting O ring in under the clip. Anybody anybody use axle stenders Bought it off a friend thinking it be some easy but not appreciate anybody thoughts
It should fix it if it hasn’t warn the ring out in the diff that the click locks into.
No one ever does. But all the quads commander and Mavericks use same diff so finding good uses normally not to hard. I’m not sure but I may have a used carrier here.
Not sure where you’re from it’s a little late where I’m from do you want to check into that and get back with me tomorrow would be great
found part of it but not the carrier. I have a complete diff with a torqlocker in it . And other parts listed for sale in the classified section all are for a 14 model .
Discussion Starter #14
Took that apart today took the clip out and compared it to another one diameter was smaller put a rubber O-ring under the bigger one put it back in went for a ride for about 2 miles stayed in Thinking it’s only a Band-Aid though Acefire Tried The trick with a hunk of metal at a 45 to see if I could
catch the edge where they c clip Locks into seems to be worn hard to tell.
Maybe oil !
1 - 19 of 19 Posts
