1 - 7 of 7 Posts
That's for models with smartlock front diff. I would guess it would be Switch activated. But if it has power when key is on there's your switch power.
But that would be the trigger wire. Wire going to switch then switch to a Relay then bar runs off Relay. That wite probably isn't heavy enough to run a bar unless it's small low wattage bar .
There’s a bus bar under the dash. Power / ground /accessory. You can hook accessories to it. I have my light bar, stereo and windshield all wired to it. I had to go through your other posts to see what machine you have. (Next time include that info). Makes it easier if we’re all on the same page.
2021 Commander XT-P
Anyone know what this connector is? Trying to find a spot to connect a light bar
I have found the same plug on my 2021 Commander XTP but can't find it's purpose. Hard to believe it's not waterproofed with a dummy plug if it's not intended to be connected. Still trying to find out what it is used for.
I have a 2022 XTP. The smart locker appears to work. But I have the same connector with white tape on it dangling. I am assuming it's a generic harness and isn't needed for the locker since the locker does seem to function. PF8 Smartlocker (front or rear locker)? Both seem to work with the switches on the dash.
1 - 7 of 7 Posts
