1 - 3 of 3 Posts
Performance Series Can Am Commander Tie Rod Kit​
TurnKey UTV performance series tie rod kit. All Turnkey UTV products are made in the U.S.A. using only the highest grade materials available. Our tie rod kit is a direct bolt on replacement drastically increasing the strength of the tie rods over the factory Commander parts. Tie rods are made from high strength 6061 aluminum and CNC shaped for precision and accuracy. Tie rod clevis is computer designed and CNC cut from 4130 steel giving your vehicle the strength and durability to handle the harshest terrain. We assemble our kits utilizing the highest quality components available from the American made Teflon coated rod ends to the grade 8 hardware. Kits come in various color options from raw aluminum to durable powder coated yellow, red & satin black. Tie rod kits come with everything required for installation including a tool to remove your factory tie rods and step by step instructions. Our kit is a direct bolt on replacement for the factory Commander tie rods and do not require any drilling, cutting or welding. Don't get stranded by a broken tie rod again.​
MSRP:
Raw aluminum- $244.95
Yellow red or black- $254.95​
Forum member price:
Raw aluminum- $232.71
Yellow, red or black-$242.20​
Enter code save5 at checkout to receive your forum price.
would you happen to have and of the hd tie rods sets in black in stock by any chance. i went to side by side sports and they said it usually ship within 1 to 2 weeks. I need these pronto if possible thanks in advance.
1 - 3 of 3 Posts
