1 - 11 of 11 Posts
Hi, i have a problem with my outlander,. When i start the engine there is a masage on bord... dps min-dps max....i have replacede drive position senzor a month ago and now shows again, when the masege apears the engine loses power..... did any one have such a problem, how can i solve it ?
1. turn key to lights on position
2. use mode button and scroll to engine hour (EH) on gauge
3. press and HOLD the mode button while quickly toggling between high and low beam ( min 3 toggles in 2 seconds)
4. If there is any P-CODES they will be displayed
Ok,I hed to replace the switch of lihts, i proceded this message
on displey there is a message FAULT 1 P00705 what das it mean,how can i fix it...?
Thak you for the answer.
Ther are 4 sensors on ger box,one the bigest is drive position senzor,and there are athers,.....do you hahe a picture which is ?
I’m going to guess that all three of those under the shift linkage are number 10. If you zoom in on number 10 it shows three sensors with 3 orings to seal them .
1 - 11 of 11 Posts
