1 - 15 of 15 Posts
My one way bearing on the primary is totally seized to the inner sheave.
any recommendations on getting it unstuck?
using lots of pb blaster…
trying to save about 400 bucks by not having to buy a new one
Discussion Starter · #4 ·
I got it off but not without great effort and totally destroying drive pulley clutch (one way assemby) and somewhat scuffing the inner sheave.
What can i do to ensure this doesnt (seizing up)happen again
I placed new one way bearing less than 100 hours ago? More grease?
What is the threshhold of needing a new sheave?
Not much you can do . Any grease that gets outside the oneway will end up on the belt. So clean everything good and hope it doesn't seize again.
Discussion Starter · #9 ·
Going through this exact problem now.....not off yet, I will try heat..
It didnt take just a little bit of heat it took a ton of heat and prying… by the time i got it off there is pits in the clutch face.
I went ahead and bought a new inner primary clutch
also the driver pulley clutchc was totally destroyed
Additionally im now uncertain if my springwasher is the right size as the bolt head can almost fit through it…
i hope you can get it off there and save money
Good luck
Cut through the clutch pully (cutting wheel) and what was left of outer bearing ...everything came off in pieces after that. Plungers were sheared off had to pick them out. Replaced pulley (cup) and bearings , better than new.
Discussion Starter · #11 ·
My parts came intoday
To put oem primary bolt on is it 89ft lbs back off 1 full turn and then re tighten?
ive read 89 and 74?
Discussion Starter · #14 ·
89# dry with factory bolt. Factory bolt is a one use bolt according to brp.
Good to know.
Thanks.
I thought it was the secondary that wasn’t reusable. Maintenance on a can am is pricey
1 - 15 of 15 Posts
