Why one use MoTul engine oil .fellow tells me the engine is much quieter with this oil than the can am oil.
I can see different oils lowering gearbox and diff noise. But I don’t believe any motor oil is going to make the engine more quiet. Your not hearing the engine other than exhaust while driving it. You are hearing the gearbox rear diff and the cvt clutch .
Couple quarts of Lucas might quiet it down or on the flip side absolutely no oil should make it
Completely silent eventually
Have you expeirenced Lucas quiteting the transmission as my xp 1000 is noisy different tones for different speeds , I sure would like to quiet it down some Thanks for the sugestions John
