1 - 3 of 3 Posts
Kris, Marineone, recently posted with regard to cold start up low oil (pressure) warning: "Have the ECM reflashed, there's an issue with the timing of the oil pressure sensor and the ECM isn't picking it up quick enough. Had this done on my '14 800XT and it solved the CEL popping up for low oil pressure."
I've seen a number of other people that have had this done while searching.
So, I went by the can-am dealer in Brookhaven, MS, which is the nearest to me and asked them about this. They had no idea and had never heard of it and acted as if it was not possible.
Does any have or can anyone get, the tsb for this? I would like to have it done at some point.
Yeah, there isn't a TSB or any alert for this. You need to have them plug in and check the version of the firmware. I can guarantee with 95% certainty it's out of date. None of the dealers will check it unless you tell them you want a version check and reflash if it's out of date.
-Kris
1 - 3 of 3 Posts
