If you've ridden in the dust, you know just how bad it can get. The coughing. The limited sight. The dust boogers. Dust in your teeth. You know what we mean.
That's why we designed the Wolfsnout Dust Mask. Riding in a group when it's super dusty out can be unbearable some days. The Wolfsnout is designed BY riders FOR riders.
We are only a few weeks away from our busy season!
Order your Wolfsnout Dust Mask TODAY to avoid the wait later!
The best riding accessory to have during the dusty summer season! SHOP HERE
Having a hard time keeping up with your buddies during the dusty summer months? Dust making it hard to breathe and slowing your down?
We had that same issue, and that's why we designed out patented dust masks! Designed BY riders that understand the problem and came up with a comfortable and effective solution!
What sets Wolfsnout Dust Masks apart from others? The patented under nose design makes it so the mask will NOT interfere with your goggles. Simply by having the nose seal under the nose rather than over, it prevents fogging and discomfort.
The mask is made out of a lightweight filter foam for comfort and effectiveness.
The dust mask can be easily washed for reuse, no buying replacement filters. Purchase HERE
Ya'll be sure to check out our facebook page! We're doing a 12 days of Christmas giveaway but it's 12 days of dust masks! Doing a giveaway for the next 12 days to get into the Christmas spirit! Our Page
The All Sport dust mask is guaranteed to be the easiest ATV/UTV dust mask to wear and breathe through on your long rides! The Wolfsnout All Sport has patented the uniquely comfortable under nose filter to work perfectly every ride and it can be worn under all types of helmets – or without a helmet at all! The Wolfsnout off-road dust mask can easily be moved out of the way by pulling it onto your chin during those short stops. You can pull it out if you like or just leave it on. The Wolfsnout is the only ATV dust mask that provides positive airflow at low speeds – You’ll even forget you’re wearing a dust mask! Unrestricted filtered breathing means cooler comfort in the summer dust. Exhaled air easily whisks away through the bottom while you play! Will NOT cause LENS FOG related to restricted air flow forcing breath under eye wear. Does not trap heat/Co2 like fabric, paper and neoprene. Can not cause discomfort to the bridge of your nose, or pinch your nose closed. Turns with your head, and does not work against your neck. You get full range of motion. The perfect fit with any helmet & goggles. Extra soft moister wicking face seal. Unbeatable comfort. Washable and reusable with a few drops of mild hand soap (Avoid harsh cleaners or detergents)…A lasting value. Unbeatable Performance 100% Guaranteed! For all off road sports. Great for landscaping too. It’s easy to rinse out the dust, dirt and grime from those dirty forest trails or sandy dunes without expensive dust mask filters to replace and not masks to throw away. Just wash it with some soap and water and squeeze out the excess water and you’re good to go – you can even wear it wet! Wearing Your ATV Dust Mask The strap should be placed high on the crown of your head. This way everything moves together and it will not pull on the back of your neck causing discomfort, and loss of mask seal. This allows the All Sport dust mask to stay in place better Purchase HERE
The All Sport dust mask is guaranteed to be the easiest ATV/UTV dust mask to wear and breathe through on your long rides! The Wolfsnout® All Sport has patented the uniquely comfortable under nose filter to work perfectly every ride and it can be worn under all types of helmets – or without a helmet at all!
