1 - 7 of 7 Posts
Made a ride up on the mountain yesterday and on the way back realized my headlights were not working. Took the cover off the fuse block and it was not hard to figure out what the problem was. The fuseblock around the headlight fuse location was melted and black as burnt toast. Removed the fuse and the wire terminals were all burnt and corroded. I am going to replace the fuse block and have looked up the part from Can-am and have come up with two numbers. 710000742 and 710003335, are either one of these correct? All my accessories are run off the second battery, so I am thinking that the headlights are pulling a ton of amps through the fuseblock. Ace, get off your high horse and tell me what I need. Thanks.
Discussion Starter · #5 ·
Hey Ace did you look for your used one. If you don't have it, let me know and I will order one. Thanks.
I will try to remember this evening I forgot all about it. Sorry
1 - 7 of 7 Posts
