On a 2011, 650 Outlander
I believe I blew a fuse in the wiring harness... somewhere!
I was testing for power at the ignition switch plug, dropped the test light, saw a small arc, and now I have no power at the key switch.
Is there an inline fuse somewhere on the harness?
All fuses on the front and back fuse boxes are good.
Couldn't see anything burnt.
I wouldn’t think being they use same system as the commanders. Sounds like a question for the resident quad guru Troy.
If they happen to use a similar set-up, power goes from battery positive to the start solenoid, then from start solenoid to the fuse panels. You might check the solenoid connection first, then the actual connections in the fuse panels
No fuse-able links . Just the fuses in the fuseboxes . Switch the fuse that you tested good up front and in rear with different fuses and see if you get power back.
