CJ- I’m not mechanically minded but I’ll tell you what they told me. The initial “cardboard tube filler” repair was not successful bc that was a band aid to absorb the resonance. The regional can am guy said that the front and rear drive assemblies should be balanced when the unit is built, but that has not happened much apparently based on the number of people having issues.
My dealer pulled front and rear drive assemblies and had them balanced at a shop locally there. When they reinstalled them and tested it he said it got rid of around 75% of the rattle. From there he said they drilled a hole in what I believe to be just the rear shaft and filled it with oil to absorb the remaining vibration and sealed it up.
I have rode around 12 hours the past 2 weekends at our ATV park and run through all scenarios of 2W/4W high/low active/trail active combinations and have not been able to create any of the rattle sound that I grew to hate so much. I don’t know where you are at regionally, I’m down in southern Missouri. I guess if you found a dealer with good service department I could give you the name of my dealer and maybe they could detail what needs to be done? I don’t know if that is an issue with it not being a “can am” produced fix for this, but if you are out of warranty I guess it wouldn’t matter bc it wouldn’t void anything. I will say it’s a totally different riding experience once you aren’t watching rpm’s to avoid the rattle and instead just enjoying your ride. Let me know if you want dealer name, I’m happy to help.
