COMMANDER™ 1000
COMMANDER 1000 SPECIFICATIONS
ENGINE
Type: 976cc, V-twin, liquid-cooled, SOHC, 8-valve (4-valve/cyl)
Bore & Stroke: 91 x 75 mm
Fuel System: iTC™ with EFI and 54mm Throttle Body, 2 Siemens VDO injectors
Starting System: Electric
Transmissi on: CVT, sub-transmission with high, low, park, neutral & reverse. Standard engine braking
Drive Train: Selectable 2WD/4WD shaft drivenwith Visco-Lok† front differential
CHASSIS
Frame: Steel
Cage type: 2-inch diameter, high-strength steel, ROPS-approved
Steering wheel adjustment: Adjustable tilt steering
Front Suspension Type/Shocks: Double A-arm with dive-control geometry / Motion Control shocks
Front Suspension Travel: 10 in (254 mm)
Rear Suspension Type Shocks: Torsional Trailing arm Independent (TTI) with external sway bar/ Motion Control shocks
Rear Suspension Travel: 10 in (254 mm)
Front Brake: Dual 214 mm ventilated disc brakes with hydraulic twin-piston calipers
Rear Brake: Single 214 mm ventilated disc brake with hydraulic twin-piston caliper
Tires/Front: Carlisle Black Rock 27 x 9 x 12 in - 686 x 229 x 305 mm
Tires/Rear: Carlisle Black Rock 27 x 9 x 12 in - 686 x 229 x 305 mm
Wheels: Steel
DIMENSIONS
L x W x H (in): 118.3 x 58.6 x 72 in
L x W x H (mm): 3,004 x 1,489 x 1,829 mm
Wheelbase: 75.8 in (1,925 mm)
Ground Clearance: 11 in (279 mm)
Dry Weight: 1,295 lbs (587 kg)
Towing Capacity: 1,500 lbs (680 kg)
Cargo Box Capacity: Total: 600 lbs (272 kg) - Upper: 400 lbs (181 kg) - Lower: 200 lbs (91 kg)
Cockpit Storage: Glove box: 4.5 gal (17.2L) - Under driver seat: 3.5 gal (13.1L)
Fuel Capacity: 10 US gal (37.8L)
FEATURES
Instrumentation: Multi-function gauge: Speedometer, tachometer, odometer, trip and hour meters, fuel, gear position, sport mode, seat belt and 4x4 indicator, diagnostics, clock, auto shut off
Anti-theft System: D.E.S.S. (Digital Encoded Security System)
Electrical: Prewired for winch
Lighting: 4 60-watt projectors with tail lights/ brake light
DC Outlet: Lighter type in console, standard connector in the back (15A)
Color Available: Yellow
WARRANTY
Basic: 6 months limited factory warranty
Extended: B.E.S.T. available from 6 to 18 months
X™ PACKAGE
• Front and rear Fox Racing Shox! HPG piggyback shocks with dual speed compression, rebound and preload adjustments
• Front sway bar
• 12-inch aluminum beadlock wheels
• Maxxis Bighorn! 2.0 tires
• Rock sliders
• Heavy-duty front bumper
• Analog/digital gauge
• Custom steering wheel with brushed aluminum center part
• X-package seat trim and graphics
• Color: Black & Yellow
XT™ PACKAGE
• BRP XL 4000 winch with roller fairlead, wired remote control and integrated winch remote storage
• 14-inch cast-aluminum wheels
• Maxxis Bighorn 2.0 tires
• Rugged bed rails
• Mudguards
• Analog / digital gauge
• Colors: Red & Yellow
