New from Kolpin - Fantastic styling, with all the features you demand from a high performance Can-Am Commander cab system! Gas door closures are also standard on this model.
Kolpin Cabs for the Can-Am Commander 800/1000; 2014 are available in the following -
Fully Accessorized Cab
Includes Full Cab System with Heater and Wiper/Washer
Full Cab - Includes Winshield, Roof, Rear Panel and Doors
Windshield Details:
All windshields are tempered glass
The automotive designed wiper/washer system is an easy installation (sold seperately)
Washer reservoir tanks are mounted for easy refilling access
Machines can be trailered at highway speeds
All windshields are full tilt
The machine can be driven in any position - including fully open, as the windshield is supported by automotive-style gas struts
Roof Details:
All roof are formed metal and powder-coated with a black finish for durability and appearance
A thin layer of foam is used on the inside roof surface to effectively dampen engine noise Securely bolted to the chassis
Trailering at highway speeds is no problem
Rear Panel Details:
Made using polycarbonate that is triple hard-coated for durability and scratch resistance
Door Details:
Doors are made with 5mm, triple hard-coated clear polycarbonate for the best visibility.
Mounted on a heavy duty, powder-coated black steel tube frame.
Weather tight, automotive type weather stripping is used for positive sealing
All doors are key matched with door locks
Doors have tempered glass sliding windows from drive and passenger. The window also features a lockable latch when closed.
All doors are easily removed with grease able, lift off hinges.
Very nice! Now the important question, what's the cost for a complete cab system?
I clicked on Can-Am Commander cab its a link... cost is $4,051.80 wow!!
AC and get us drinks! lol
