Got several things I'm gonna so if yall can give insight on so I'm gonna number them and if you have an answer for any I'd appreciate the help.
1. The most important thing is I'm having problems shifting my 1000xt. It started giving me problems after I had my belt changed. My dad's friend, who is a good atv mechanic just not experienced in can ams, did it for me and said the belt(gates g force) was extremely tight when he got done. I know he took both clutches off when he changed the belt. Dud he maybe not put the clutches back in properly or is the belt just misaligned or something else?
2. Along the same lines with the belt, the can am will creap up on its on while in gear. It also squeals while in gear not giving any gas Once you give it gas the squeal is gone. If it is in gear and not moving the belt will start to smoke. If in neutral idling there is no squeal. Is the belt just wearing in or is it misaligned?
3. I was looking at my shocks and on one of my shocks I noticed some bubbling, i know im probably using the wrong termination here, on the top of the cylinder where the shafts goes in. Not normal is it?
4. I was in some pretty bad trails the other day and was having problems coming out of a rut so I back up and jump on it. Well my tires hit the end of the rut down come out and I hear a pop, not like an axle. Well over the next few days my steering starts getting loose, 1/4 to a 1/2 turn off according to the steering wheel. So I did some looking for a rack and pinion and saw a recall on 2011 to 2012 commanders rack and pinion which mine would fall into that category, do you think now that it's broke I could still get a claim on the recall? Also I never received anything in the mail regarding this recall like I did on the leaves and dry grass around the exhaust but according to the recall list min should fall into the umbrella.
