My commander 700 2023 has 3 warning codes
288 Views 9 Replies 3 Participants Last post by  cannedham
I would like to know if anyone has experienced or knows what these codes mean on the board:
P3005
P3015
P30D3
who can help me with this problem.
1 - 10 of 10 Posts
I have seen a bunch of p code over the yrs . That’s that first time I have seen those . Nor can I find anything on the related to a gas engine . I did find the 3015 which referred back to a HV battery and or Internal ecm battery which to my knowledge can am doesn’t use . And could find anything on the third code that was vehicle related .
But I do see that the last 7 ip addresses that you have used to post one thread . Are all linked and marked as spam accounts.
So next post needs to be a good one .
Thanks for the help I have downloaded a service manual for him and those codes do not appear either, the workshop where I bought it does not know how to tell me either, they want me to take it for a scan, but I would like to know beforehand what it is because they installed some accessories to make it street legal and they worked with the electrical to install signal lights and the whinch and I wanted to know if the problem must be that they did a bad job is a new vehicle.[/QUOTE]
Reactions: 1
Well if those are correct. Sounds like they may have spliced into something they shouldn’t have . If you have a can an dealer local they can scan it and give you a quote on fixing the problem . That will also verify what the codes mean to can am . I do know can am p code most of the time are same as ford and gm. But they have a lot of codes that are different. With same o code number.
Where are you located??
The flag by his username is Puerto Rico. If you're heading his way to hook it up to BUDS, I'd like to tag along.:cool:
Reactions: 1
I’m on tapatalk there’s no flags .
I guess that's a "no".:cry:
1 - 10 of 10 Posts
