Can am overhead switch panel (needed another switch spot for my whips)
Lmao.pic#1: I like the shirt...a lot....can't wear that everywhere, though.
pic#2: Is that $65 worth of gas in the background?
pic#3: Is that an electric pressure washer in the background? If so, does it work well? I just put a new pump on my gas unit. That was before gas hit $26 dollars a gallon.
pic#4: Do you think that's going to hold up to the elements?
pic#5: Does that double as a snack tray?....booster seat?
That's all I got.....you're probably glad.![]()
re: #3 - I picked up a cheap Ryobi electric pressure washer at Homie's and really like it for cleaning vehicles. I bought a longer hose (guy thing) but otherwise it's just right. Because it's a low-end washer, it doesn't have too much pressure so I don't have to worry about causing damage or over-penetration (never a problem for me anyway).pic#1: I like the shirt...a lot....can't wear that everywhere, though.
I understand, Stevie. Looking back, I probably should have thought longer and harder before investing in "the pump". The wife likes to use it around the house. She argues that if she had an electric unit, it would be "plug and play" for her, and she wouldn't need me around to get it started or finish the job. My hose, too, has never seemed long enough, although it's lost virtually all of it's stiffness with age. Such is life.re: #3 - I picked up a cheap Ryobi electric pressure washer at Homie's and really like it for cleaning vehicles. I bought a longer hose (guy thing) but otherwise it's just right. Because it's a low-end washer, it doesn't have too much pressure so I don't have to worry about causing damage or over-penetration (never a problem for me anyway).
Yes. I installed all of my accessories myself.Did you install the overhead switch panel yourself?
How was the install? I have one on order. I have backup lights and an interior lights going up. Does the panel have its own busbar?Yes. I installed all of my accessories myself.![]()
Was this hard to install? Where did you pick it up?![]()
Can am device holder
No it was easy. Took maybe 15 minutes. Bought from can am.Was this hard to install? Where did you pick it up?
