I was swapping my plastic water necks to mrRPMs cast ones. Passender side with the thermostat went fine, on the driver's side one bolt went in fine and the other went in almost all the way and the top snapped off. I must have had it cross threaded. I let her run a whole and I see dribbles from both bleed screws but not from the broken bolt area.
It's tight but should I try to drill it out and go through retapping or jb weld it and call it a day. Also I didn't see any in the Mr rpm kit but I'm guessing that the bleed bolts should have a fiber washer to seal them? Thanks in advance.
I also got some copper sealing washers to seal the bleed bolts. I'm back in business 👌
